The following tables describe proprietary traps for the switch. All of the following traps have a status of current.
| OID | Notification type | Objects | Description |
| 1.3.6.1.4.1.45.4.8.0.1 | slaMonitorAgentExceptionDetected | slaMonitorAgentExceptionDetected | The SLA Monitor (SLA Mon) agent process has terminated unexpectedly. You must reenable SLA Monitor to restart the SLA Monitor agent. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.45.5.17.0.1 |
bsDhcpSnoopingBindingTableFull |
bsDhcpSnoopingNotificationClientMACAddr |
A bsDhcpSnoopingBindingTableFull notification is generated when you try adding a new DHCP binding entry, and the binding table is full. The value of bsDhcpSnoopingNotificationClientMACAddr gives the MAC address that cannot be added to the binding table. This notification also indicates that additional untrusted DHCP packets will not be added to the binding table, and will be dropped. |
1.3.6.1.4.1.45.5.17.0.2 |
bsDhcpSnoopingTrap |
A bsDhcpSnoopingTrap notification is generated when a DHCP packet is dropped. |
1.3.6.1.4.1.45.5.17.0.4 |
bsDhcpSnoopingStaticEntryMACConflict |
bsDhcpSnoopingNotificationSourceMACAddr bsDhcpSnoopingIfIndex |
A bsDhcpSnoopingStaticEntryMACConflict notification is generated when a DHCP packet is dropped, because a static entry with the same MAC address was found in the binding table. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.45.5.18.0.1 |
bsaiArpPacketDroppedOnUntrustedPort |
A bsaiArpPacketDroppedOnUntrustedPort trap signifies that an ARP packet is dropped on an untrusted port, due to an invalid IP or MAC address binding. The port is identified by the instance of bsArpInspectionIfTrusted generated by the trap. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.45.5.20.0.2 |
bsSourceGuardCannotEnablePort |
bsSourceGuardConfigMode |
A bsSourceGuardCannotEnablePort trap signifies that there are insufficient resources to enable IP Source Guard checking on a port because of internal state changes within the system such as system initialization. The port is identified by the instance of bsSourceGuardConfigMode generated by the trap. |
1.3.6.1.4.1.45.5.20.0.1 |
bsSourceGuardReachedMaxIpEntries |
A bsSourceGuardReachedMaxIpEntries trap signifies that the maximum number of IP address entries on a port has been reached. The port is identified by the instance of bssourceGuardConfigMode generated by the trap. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.45.5.34.0.1 |
bsnesGloballyEnabled |
A bsnesGloballyEnabled trap signifies that the Energy Saver feature was enabled globally. |
1.3.6.1.4.1.45.5.34.0.2 |
bsnesGloballyDisabled |
A bsnesGloballyDisabled trap signifies that the Energy Saver feature was disabled globally. |
1.3.6.1.4.1.45.5.34.0.3 |
bsnesManuallyActivated |
A bsnesManuallyActivated trap signifies that the Energy Saver was activated manually. |
1.3.6.1.4.1.45.5.34.0.4 |
bsnesManuallyDeactivated |
A bsnesManuallyDeactivated trap signifies that the Energy Saver feature was deactivated manually. |
1.3.6.1.4.1.45.5.34.0.5 |
bsnesScheduleNotApplied |
A bsnesScheduleNotApplied trap signifies that a schedule was not applied because SNTP is not synchronized. |
1.3.6.1.4.1.45.5.34.0.6 |
bsnesScheduleApplied |
A bsnesScheduleApplied trap signifies that SNTP is synchronized and the schedule is being applied. |
1.3.6.1.4.1.45.5.34.0.7 |
bsnesActivated |
A bsnesActivated trap signifies that the Energy Saver feature was activated by the schedule. |
1.3.6.1.4.1.45.5.34.0.8 |
bsnesDeactivated |
A bsnesDeactivated trap signifies that the Energy Saver feature was deactivated by the schedule. |
ODID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.45.5.43.0.1 |
bsLstInterfaceStatusChanged |
A bsLstInterfaceStatusChanged trap signifies that a physical or logical interface changed status in a Link-state tracking (LST) tracking group. |
1.3.6.1.4.1.45.5.43.0.2 |
bsLstInterfaceOperStateChanged |
A bsLstInterfaceOperStateChanged trap signifies that the operational status of an LST group changed due to an interface status change. For example, when the last interface in an LST group is down, the operational status of theLST group changes to down. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.2272.1.4.10.1.1.114 |
rcPortShutdownReason |
An rcPortShutdownReason trap signifies that the specific VLACP link port status is down as VLACP flaps are detected on that port. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.2272.1.21.0.3 |
rcnErrorNotification |
rcErrorLevel rcErrorCode rcErrorText |
An rcnErrorNotification trap signifies that the SNMPv2 entity, acting in an agent role, has detected an error condition. |
1.3.6.1.4.1.2272.1.21.0.4 |
rcnStpNewRoot |
rcStgId |
An rcnStpNewRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Spanning Tree Protocol declared the device to be the new root of the spanning tree. |
1.3.6.1.4.1.2272.1.21.0.5 |
rcnStpTopologyChange |
rcStgId rcPortIndex |
An rcnStpTopologyChange trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Spanning Tree Protocol has gone due to a topology change event. |
1.3.6.1.4.1.2272.1.21.0.6 |
rcnChasPowerSupplyDown |
An rcnChasPowerSupplyDown trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasPowerSupplyOperStatus object for one of its power supply units is about to transition into the down state. |
1.3.6.1.4.1.2272.1.21.0.7 |
rcnChasFanDown |
An rcnChasFanDown trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasFanOperStatus object for one of its power supply units is about to transition into the down state. |
1.3.6.1.4.1.2272.1.21.0.8 |
rcnLinkOscillation |
rcPortIndex |
An rcnLinkOscillation trap signifies that the SNMPv2 entity, acting in an agent role, has detected an excessive number of link state transitions on the specified port. |
1.3.6.1.4.1.2272.1.21.0.9 |
rcnMacViolation |
An rcnMacViolation trap signifies that the SNMPv2 entity, acting in an agent role, has received a PDU with an invalid source MAC address. |
1.3.6.1.4.1.2272.1.21.0.13 |
rcn2kTemperature |
rc2kChassisTemperature |
An rcn2kTemperature trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the chassis is overheating. |
1.3.6.1.4.1.2272.1.21.0.14 |
rcnChasPowerSupplyUp |
An rcnChasPowerSupplyUp trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasPowerSupplyOperStatus object for one of its power supply units is about to transition into the up state. |
1.3.6.1.4.1.2272.1.21.0.16 |
rcnStpTCN |
An rcnStpTCN trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Spanning Tree Protocol has gone due to a topology change event. |
1.3.6.1.4.1.2272.1.21.0.17 |
rcnSmltIstLink Up |
An rcnSmltIstLinkUp trap signifies that the split MLT link is from down to up. |
1.3.6.1.4.1.2272.1.21.0.18 |
rcnSmltIstLink Down |
rcnSmltIstLinkDown |
An rcnSmltIstLinkDown trap signifies that the split MLT link is from up to down. |
1.3.6.1.4.1.2272.1.21.0.19 |
rcnSmltLinkUp |
rcMltSmltId |
An rcnSmltLinkUp trap signifies that the split SMLT link is up. |
1.3.6.1.4.1.2272.1.21.0.20 |
rcnSmltLinkDo wn |
rcMltSmltId |
An rcnSmltLinkDown trap signifies that the split SMLT link is down. |
1.3.6.1.4.1.2272.1.21.0.21 |
rcnChasFanUp |
An rcnChasFanUp trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the rcChasFanOperStatus object for one of its power supply units is about to transition into the up state. |
1.3.6.1.4.1.2272.1.21.0.22 |
rcnPasswordChange |
An rcnPasswordChange trap signifies that the SNMPv2 entity, acting in an agent role, has detected that one of the CLI passwords is changed. |
1.3.6.1.4.1.2272.1.21.0.23 |
rcnEmError |
An rcnEmError trap signifies that the SNMPv2 entity, acting in an agent role, has detected an Em error. |
1.3.6.1.4.1.2272.1.21.0.26 |
rcnSmartCpldTimerFired |
rc2kCardIndex |
An rcnSmartCpldTimerFired trap signifies that the CP ID timer fired. |
1.3.6.1.4.1.2272.1.21.0.27 |
rcnCardCpldNotUpDate |
rc2kCardIndex |
An rcnCardCpldNotUpDate trap signifies that the CP ID is not up-to-date. |
1.3.6.1.4.1.2272.1.21.0.28 |
rcnIgapLogFileFull |
An rcnIgapLogFileFull trap signifies that the IGAP accounting time-out Log File has reached the maximum. |
1.3.6.1.4.1.2272.1.21.0.30 |
rcnSshServerEnabled |
rcSshGlobalPort |
An rcnSshServerEnabled trap signifies that the SSH server is enabled. |
1.3.6.1.4.1.2272.1.21.0.31 |
rcnSshServerDisabled |
rcSshGlobalPort |
An rcnSshServerDisabled trap signifies that the SSH server is disabled. |
1.3.6.1.4.1.2272.1.21.0.37 |
rcnSaveConfigAction |
rcSysActionL1 |
An rcnSaveConfigAction trap indicates that the switch run time or boot configuration is being saved. |
1.3.6.1.4.1.2272.1.21.0.38 Note:
This trap does not apply to all platforms. |
rcnLoopDetectOnPort |
An rcnLoopDetectOnPort trap indicates that a loop has been detected on a port. The VLAN on that port will be disabled. |
1.3.6.1.4.1.2272.1.21.0.41 |
rcnAggLinkUp |
rcMltId |
An rcnAggLinkUp trap is generated when the operational state of the aggregator changes from down to up. |
1.3.6.1.4.1.2272.1.21.0.42 |
rcnAggLinkDown |
rcMltId |
An rcnAggLinkDown trap is generated when the operational state of the aggregator changes from up to down. |
1.3.6.1.4.1.2272.1.21.0.59 |
rcnFdbProtectViolation |
The rcnFdbProtectViolation trap signifies that the port has violated the user-configured limit for total number of fdb-entries learned on that port. |
1.3.6.1.4.1.2272.1.21.0.60 |
rcnLogMsgControl |
An rcnLogMsgControl trap signifies whether the number of times of repetition of the particular Log message has exceeded the particular frequency or count. |
1.3.6.1.4.1.2272.1.21.0.61 |
rcnSaveConfigFile |
An rcnSaveConfig trap signifies that either the runtime config or the boot config has been saved on the switch. |
1.3.6.1.4.1.2272.1.21.0.62 |
rcnDNSRequestResponse |
An rcnDnsRequestResponse trap signifies that the switch sent a query to the DNS server or that it received a successful response from the DNS Server. |
1.3.6.1.4.1.2272.1.21.0.63 |
rcnDuplicateIpAddress |
An rcnDuplicateIpAddress trap signifies that a duplicate IP address is detected on the subnet. |
1.3.6.1.4.1.2272.1.21.0.64 |
rcnLoopDetectPortDown |
An rcnLoopDetectPortDown trap signifies that a loop has been detected on a port and the port is going to shut down. |
1.3.6.1.4.1.2272.1.21.0.67 |
rcnLoopDetectMacDiscard |
An rcnLoopDetectMacDiscard trap signifies that a loop has been detected on a port and the MAC address will be discarded on all ports in that VLAN. |
1.3.6.1.4.1.2272.1.21.0.68 |
rcnAutoRecoverPort |
rcPortIndex |
An rcnAutoRecoverPort trap signifies that autorecovery has reenabled a port that was previously disabled by link flap. |
1.3.6.1.4.1.2272.1.21.0.69 |
rcnAutoRecoverLoopDetectedPort |
rcVlanNewLoopDetectedAction |
An rcnAutoRecoverPort trap signifies that autorecovery has cleared the loop detect action that was taken on a port. |
1.3.6.1.4.1.2272.1.21.0.74 |
rcnTacacsAuthFailure |
rcTacacsGlobalLastUserName |
An rcnTacacsAuthFailure trap signifies that TACACS+ authentication failed for a user. |
1.3.6.1.4.1.2272.1.21.0.75 |
rcnTacacsNoServers |
An rcnTacacsNoServers trap signifies that you are unable to use any TACACS+ servers for authentication. |
1.3.6.1.4.1.2272.1.21.0.76 |
rcnTacacsRxUnsupportedFrame |
An rcnTacacsRxUnsupportedFrame trap signifies that an unsupported frame was received from the TACACS+ server. |
1.3.6.1.4.1.2272.1.21.0.77 |
rcnTacacsExceededMaxLogins |
An rcnTacacsExceededMaxLogins trap signifies that there was an attempt to exceed the maximum number of allowed TACACS+ logins. |
1.3.6.1.4.1.2272.1.21.0.78 |
rcnTacacsClientFailure |
An rcnTacacsClientFailure trap signifies that the TACACS+ Client application is down. |
1.3.6.1.4.1.2272.1.21.0.80 |
rcnVlacpPortDown |
rcPortIndex |
An rcnVlacpPortDown trap signifies that VLACP is down on the port specified. |
1.3.6.1.4.1.2272.1.21.0.81 |
rcnVlacpPortUp |
rcPortIndex |
An rcnVlacpPortUp trap signifies that VLACP is up on the port specified. |
1.3.6.1.4.1.2272.1.21.0.83 |
rcnEapMacIntrusion |
An rcnEapMacIntrusion trap signifies that an EAP MAC intrusion has occurred on this port. |
1.3.6.1.4.1.2272.1.21.0.110 |
rcnMaxRouteWarnClear |
rcVrfName |
An rcnMaxRouteWarnClear trap signifies that the number of routes in the routing table of the virtual router has dropped below the warning threshold. |
1.3.6.1.4.1.2272.1.21.0.111 |
rcnMaxRouteWarnSet |
rcVrfName |
An rcnMaxRouteWarnSet trap signifies that the routing table for the virtual router is reaching its maximum size. Take action to prevent this. |
1.3.6.1.4.1.2272.1.21.0.112 |
rcnMaxRouteDropClear |
rcVrfName |
An rcnMaxRouteDropClear trap signifies that the routing table for the virtual router is no longer dropping new routes as it is below the maximum size. |
1.3.6.1.4.1.2272.1.21.0.113 |
rcnMaxRouteDropSet |
rcVrfName |
An rcnMaxRouteDropSet trap signifies that the routing table for the virtual router has reached the maximum size, and is now dropping all new nonstatic routes. |
1.3.6.1.4.1.2272.1.21.0.117 |
rcnMstpNewCistRoot |
rcStgBridgeAddress |
An rcnMstpNewCistRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Multiple Spanning Tree Protocol has declared the device to be the new root of the common internal spanning tree. |
1.3.6.1.4.1.2272.1.21.0.118 |
rcnMstpNewMstiRoot |
An rcnMstpNewMstiRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Multiple Spanning Tree Protocol has declared the device to be the new root of the spanning tree instance. |
1.3.6.1.4.1.2272.1.21.0.119 |
rcnMstpNewCistRegionalRoot |
An rcnMstpNewCistRegionalRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Multiple Spanning Tree Protocol has declared the device to be the new regional root of the common internal spanning tree. |
1.3.6.1.4.1.2272.1.21.0.120 |
rcnRstpNewRoot |
An rcnRstpNewRoot trap signifies that the SNMPv2 entity, acting in an agent role, has detected that the Rapid Spanning Tree Protocol has declared the device to be the new root of the spanning tree. |
1.3.6.1.4.1.2272.1.21.0.124 |
rcnRsmltEdge PeerModified |
rcVlanId |
An rcnRsmltEdgePeerModified trap signifies that the RSMLT peer address is different from that of the stored address. You must save the configuration if EdgeSupport has to use this information on the next restart. |
1.3.6.1.4.1.2272.1.21.0.143 |
rcn2kGbicRemoved |
An rcGbicRemoved trap signifies that the SNMPv2 entity, acting in an agent role has detected that an XFP or SFP is removed from the specified slot or port. |
1.3.6.1.4.1.2272.1.21.0.144 |
rcn2kGbicInserted |
An rcGbicInserted trap signifies that the SNMPv2 entity, acting in an agent role has detected that the an XFP or SFP is inserted in the specified slot or port. |
1.3.6.1.4.1.2272.1.21.0.167 |
rcnChasPowerSupplyNoRedundancy |
An rcnChasPowerSupplyNoRedundancy trap signifies that the chassis is running on a power supply without redundancy. |
1.3.6.1.4.1.2272.1.21.0.168 |
rcnChasPowerSupplyRedundancy |
An rcnChasPowerSupplyRedundancy trap signifies that the chassis is running on a power supply with redundancy. |
1.3.6.1.4.1.2272.1.21.0.171 |
rcnLicenseTrialPeriodExpired |
An rcnLicenseTrialPeriodExpired trap signifies that the Trial Period License has expired. |
1.3.6.1.4.1.2272.1.21.0.172 |
rcnLicenseTrialPeriodExpiry |
rcSysLicenseTrialDaysLeft |
An rcnLicenseTrialPeriodExpiry trap signifies the time remaining, in days, before the Trial Period License expires. |
1.3.6.1.4.1.2272.1.21.0.173 |
rcnVrfUp |
rcVrfName rcVrfOperStatus |
This notification is generated when the operational status of the specified VRF is toggled from down to up. |
1.3.6.1.4.1.2272.1.21.0.174 |
rcnVrfDown |
This notification is generated when the operational status of the specified VRF is toggled from up to down. |
1.3.6.1.4.1.2272.1.21.0.175 |
rcnMrouteIngressThresholdExceeded |
This notification is generated when the number of mroute ingress records exceeds the ingress threshold. |
1.3.6.1.4.1.2272.1.21.0.176 |
rcnMrouteEgressThresholdExceeded |
This notification is generated when the number of mroute egress records exceeds the egress threshold. |
1.3.6.1.4.1.2272.1.21.0.185 |
rcnChasPowerSupplyRunningLow |
An rcnChasPowerSupplyRunningLow trap signifies that the chassis is running on low power supply. |
1.3.6.1.4.1.2272.1.21.0.192 |
rcnIsisPlsbMetricMismatchTrap |
An rcnIsisPlsbMetricMismatchTrap signifies that a Link State Packet (LSP) with a different value of Level 1 metric is received. |
1.3.6.1.4.1.2272.1.21.0.193 |
rcnIsisPlsbDuplicateSysidTrap |
An rcnIsisPlsbduplicateSysidTrap signifies that a Hello packet with a duplicate system ID is received. |
1.3.6.1.4.1.2272.1.21.0.194 |
rcnIsisPlsbLsdbUpdateTrap |
rcIsisPlsbTrapType |
An rcnIsisPlsbLsdbUpdateTrap signifies that link state database (LSDB) information has changed. |
1.3.6.1.4.1.2272.1.21.0.196 |
rcnChasFanCoolingLow |
An rcnaChasFanCoolingLow trap signifies that the chassis is running on low fan cooling. |
1.3.6.1.4.1.2272.1.21.0.278 |
rcnIsisPlsbBvidMismatchTrap |
An rcnIsisPlsbBvidMismatchTrap signifies when a backbone VLAN ID (BVID) Type-Length-Value (TLV) from a neighbor node does not match the local configuration. |
1.3.6.1.4.1.2272.1.21.0.279 |
rcnIsisPlsbSmlt VirtBmacMism atchTrap |
An rcnIsisPlsbSmltVirtBmacMis matchTrap signifies that the virtual Backbone MAC (BMAC) configured in the switch is different from the virtual BMAC configured on the interswitch trunking (IST) peer. |
1.3.6.1.4.1.2272.1.21.0.280 |
rcnIsisPlsbSmlt PeerBmacMis matchTrap |
An rcnIsisPlsbSmltPeerBmacMis matchTrap signifies one of the following situations:
1.3.6.1.4.1.2272.1.21.0.281 |
rcnIsisPlsbAdjStateTrap |
An rcnIsisPlsbAdjStateTrap signifies when IS-IS adjacency state changes. |
1.3.6.1.4.1.2272.1.21.0.282 |
rcnIsisPlsbDuplicateNNameTrap |
An rcnIsisPlsbDuplicateNNameTrap signifies that a Link State Packet (LSP) with a duplicate nickname is received. The trap should be generated by all the switches in the network. |
1.3.6.1.4.1.2272.1.21.0.283 |
rcnIsisPlsbSmlt SplitBebMisma tchTrap |
An rcnIsisPlsbSmltSplitBebMism atchTrap signifies that the SMLT Split Backbone Edge Bridge (BEB) configured on the local switch and on the IST peer are the same. One IST switch must be configured as the primary Split BEB and the other IST peer must be configured as the secondary Split BEB. |
1.3.6.1.4.1.2272.1.21.0.284 |
rcnIsisPlsbMultiLinkAdjTrap |
An rcnIsisPlsbMultiLinkAdjTrap signifies when the Intermediate-System-to-Intermediate-System (IS-IS) protocol forms more than one adjacency with the same IS-IS. |
1.3.6.1.4.1.2272.1.21.0.285 |
rcnaSshSessionLogout |
rcSshGlobalHostIpAddr |
An rcnaSshSessionLogout trap signifies a Secure Shell (SSH) session logout. |
1.3.6.1.4.1.2272.1.21.0.286 |
rcnaSshUnauthorizedAccess |
An rcnaSshUnauthorizedAccess trap signifies that unauthorized access has occurred. It is deprecated by rcnaSshUnauthorizedAccess. |
1.3.6.1.4.1.2272.1.21.0.287 |
rcnaAuthenticationSuccess |
An rcnaAuthenticationSuccess trap signifies that a login is successful. The Trap includes the login username and the host IP address. It is deprecated by rcnaAuthenticationSuccess. |
1.3.6.1.4.1.2272.1.21.0.288 |
rcnaSshSessionLogin |
An rcnaSshSessionLogin trap signifies that there is a Secure Shell (SSH) session login. |
1.3.6.1.4.1.2272.1.21.0.305 |
RcIsisPlsbSmltVirtBmacMisconfigTrap |
An SPBM ISIS trap signifies that SMLT virtual BMAC has been used by nodes other than the SMLT nodes as system-id or MAC. |
1.3.6.1.4.1.2272.1.21.0.306 Note:
rcnPortChannelizedStateChangeTrap |
An rcnPortChannelizedStateChangeTrap notification signifies that a port channelized state has changed by administratively enabling or disabling. |
1.3.6.1.4.1.2272.1.21.0.335 |
rcnSystemUsbInternalAccessErrorTrap |
An rcnSystemUsbInternalAccessErrorTrap notification signifies that the system has lost internal access to the USB. This trap only applies to platforms that require the USB as part of the operating system. |
1.3.6.1.4.1.2272.1.21.0.341 |
rcnDvrVistPeerDomainMismatchErrorTrap |
rcIsisPeerVirtualBmac |
An rcnDvrVistPeerDomainMismatchErrorTrap notification is generated when the VIST link comes up between two DvR peers that are in different DvR domains. |
1.3.6.1.4.1.2272.1.21.0.342 |
rcnDvrVistPeerDomainMismatchErrorClearTrap |
An rcnDvrVistPeerDomainMismatchErrorTrap notification is generated when the error condition of having a VIST link up between two DvR peers from different DvR domains is cleared. |
1.3.6.1.4.1.2272.1.21.0.351 |
rcnIsisPlsbIsisEnabledWithZeroNicknameTrap |
An rcnIsisPlsbIsisEnabledWithZeroNicknameTrap notification is generated when the IS-IS is enabled with a zero nickname. |
1.3.6.1.4.1.2272.1.21.0.352 |
rcnRestConfServerOperationStatusTrap |
rcnRestConfServerOperationStatus |
An rcnRestConfServerOperationStatusTrap notification is generated when the RESTCONF server is enabled or disabled to indicate the operational status of the RESTCONF server. |
OID |
Notification type |
Objects |
Description |
1.3.6.1.4.1.2272.1.206.1.0.1 |
rcVrrpTmpTrapNewMaster |
This notification is generated when Virtual Router Redundancy Protocol (VRRP) transitions to the master. |
1.3.6.1.4.1.2272.1.206.2.2.1 |
rcVrrpExtTrapStateTransition |
This notification is generated when a transition happens in the state of Virtual Router Redundancy Protocol (VRRP), for instance, a transition from master to backup when shutdown is received. |
