View Ping Probe History
View the ping probe history to view the history of ping tests performed by the switch.
![Note](images/note.png)
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Click Ping/Trace Route.
- Select a ping entry.
- Click Ping Probe History.
Ping Probe History Field Descriptions
Use the data in the following table to use the Ping Probe History tab.
Name |
Description |
OwnerIndex |
Specifies the owner index |
TestName |
Indicates the name given to the test. |
Index |
Specifies the index number. |
Response |
Indicates the amount of time, measured in milliseconds, between request (probe) and response, or when the request timed out. Response is reported as 0 when it is not possible to transmit a probe. |
Status |
Indicates the status of the response; the result of a particular probe done by a remote host. |
LastRC |
Indicates the last implementation-method-specific reply code (RC) received. If ICMP Echo is used, then a successful probe ends when an ICMP response is received that contains the code ICMP_ECHOREPLY(0). |
Time |
Indicates the timestamp for this probe result. |
