View IPv6 Default Routers
View the table of default routers learned from router advertisement messages.
A maximum of four routers are visible in the default routers list.
- In the navigation tree, expand .
- Select IPv6.
- Select the Default Routers tab.
Default Routers field descriptions
Use the data in the following table to use the Default Routers tab.
Name |
Description |
Address |
Specifies the learned router address for an IPv6 default routers entry. |
IfIndex |
Specifies the interface number for an IPv6 default routers entry. |
Lifetime |
Specifies the remaining router lifetime. |
Active |
Specifies if the default router is active for an IPv6 default routers entry. |
