Configure IPsec Compression
This procedure only applies to VSP 4900 Series and VSP 7400 Series using Fabric IPsec Gateway.
Ensure IPsec fragmentation before encryption is disabled.
Perform this procedure to enable IPsec compression on Fabric IPsec Gateway Virtual Machine (VM).
By default, IPsec compression is disabled. You must enable IPsec compression on both ends of the adjacency.
  1. Enter Fabric IPsec Gateway Configuration mode:
    enable
    virtual-service WORD<1-128> console
    Type CTRL+Y to exit the console.
  2. Enable IPsec compression:
    set ipsec compression
