Exception: not supported on VSP 8600 Series.
Enables or disables flow control globally. When disabled, the system does not generate nor configure the transmission of flow control messages. The system always honors received flow control messages regardless of the flow control mode status. You must enable this mode before you configure an interface to send pause frames.
The default is disabled.
enable
configure terminal
boot config flags flow-control-mode
