This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote DvR host entries (IPv4 remote ARPs) on either a Controller or a Leaf node. The node displays the host entries learned either locally on its UNI port or dynamically from other nodes in the DvR domain.
Ensure that you enable DvR globally on the node.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select DVR Remote.
  3. Select the Host Entries tab.
  4. Optional: To filter the rows based on the specific criteria, click Filter.
Host Entries Field Descriptions
Use the data in the following table to use the Host Entries tab.
Name
Description
IpAddrType
Specifies the address type of the DvR host entry (IPv4 remote ARP).
IpAddr
Specifies the IPv4 address of the DvR host entry.
Mask
Specifies the subnet mask of the DvR host entry.
L3Isid
Specifies the Layer 3 I-SID of the DvR host entry.
MacAddr
Specifies the MAC address of the DvR host entry.
L2Isid
Specifies the Layer 2 I-SID of the DvR host entry.
VrfId
Specifies the VRF ID associated with the DvR host entry.
Port
Specifies the port of the DvR host entry.
DomainId
Specifies the DvR domain ID of the DvR host entry.
Type
Specifies the host type of the DvR host entry.
NextHopName
Specifies the next hop system name of the DvR host entry.
NextHopMac
Specifies the next hop system MAC address of the DvR host entry.
ClearEntry
Clears the entry if the configured value is true.
