For IPv4, enter: show ip interface gigabitethernet
For IPv6, enter: show ipv6 interface gigabitethernet
Verify the IPv4 configuration on the port:
Switch:1(config-if)# show ip interface gigabitethernet
Brouter Port Ip
PORT VRF IP_ADDRESS NET_MASK ADMIN OPER ADVERTISE DIRECT RPC RPCMODE
NUM NAME STATUS STATUS WHEN_DOWN BCAST
1/1 Glob~ 192.0.2.3 255.255.255.0 enable up disable disable disable exist-only
1/10 spbo~ 198.51.100.4 255.255.255.0 enable up disable disable disable exist-only
PORT VRF BROADCAST REASM
NUM NAME MAXSIZE
1/1 GlobalRouter ones 1500
1/10 spboip ones 1500
Verify the IPv6 configuration on the port:
Switch:1(config-if)#show ipv6 interface gigabitethernet
Port Ipv6 Interface
IFINDX BROUTER PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT MCAST IPSEC RPC RPCMODE
INDX ADDRESS STATE STATE LMT TIME TIME STATUS
192 4/16 e4:5d:52:3c:65:02 enable down ETHER 1500 2 30000 1000 disable disable disable existonly
Port Ipv6 Address
IPV6 ADDRESS BROUTER TYPE ORIGIN STATUS
2001:db8:0:0:0:0:0:ffff/64 4/16 UNICAST MANUAL INACCESSIBLE INF INF
2001:db8:0:0:e65d:52ff:fe3c:6502/64 4/16 UNICAST LINKLAYER INACCESSIBLE INF INF
1 out of 5 Total Num of Interface Entries displayed.
2 out of 10 Total Num of Address Entries displayed.
