Use the following procedure to configure the change interval rule. The system enforces a minimum password change interval, which defines the minimum amount of time before you can change to a new password. By default, the minimum change interval is 24 hours between changing from one password to a new password.
You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
Configure the change interval rule to 72 hours:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#password change-interval 72 Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password change-interval command.
Variable |
Value |
<1–999> |
Configures the minimum interval between consecutive password changes. The default is 24 hours. |
