Use this procedure to configure the timeout value in the GRT. The timeout value ages out the sender when there are no multicast streams coming from the sender for a specified period of time in seconds. The default timeout value is 210 seconds.
  • You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
  • You must create the C-VLANs and add slots/ports.
  • You must enable IP Multicast over Fabric Connect globally.
  1. Enter IS-IS Router Configuration mode:
    enable
    configure terminal
    router isis
  2. Configure the IP Multicast over Fabric Connect forward-cache timeout:
    spbm <1–100> multicast fwd-cache-timeout(seconds) <10–432000>
  3. Optional: Configure the IP Multicast over Fabric Connect forward-cache timeout to the default value of 210 seconds:
    default spbm <1–100> multicast fwd-cache-timeout(seconds)
    no spbm <1–100> multicast fwd-cache-timeout(seconds)
Configure the IP Multicast over Fabric Connect forward-cache timeout to 300:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#spbm 1 multicast 1 fwd-cache-timeout 300
