The switch uses RADIUS servers for authentication and accounting services. Use the no form to delete a RADIUS server.
  • You must enable EAP globally.
The RADIUS server uses the secret key to validate users.
RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration.
    enable
    configure terminal
  2. Add an EAP-enabled RADIUS server:
    radius server host WORD <0–46> used-by eapol acct-enable
    radius server host WORD <0–46> used-by eapol acct-port <1-65536>
    radius server host WORD <0–46> used-by eapol enable
    radius server host WORD <0–46> used-by eapol key WORD<0-20>
    radius server host WORD <0–46> used-by eapol port <1-65536>
    radius server host WORD <0–46> used-by eapol priority <1-10>
    radius server host WORD <0–46> used-by eapol retry <0-6>
    radius server host WORD <0–46> used-by eapol secure-enable
    radius server host WORD <0–46> used-by eapol secure-log-level
    radius server host WORD <0–46> used-by eapol secure-mode
    radius server host WORD <0–46> used-by eapol secure-profile
    radius server host WORD <0–46> used-by eapol timeout <1-180>
    By default, the switch uses RADIUS UDP port 1812 for authentication, and port 1813 for accounting. You can change the port numbers or other RADIUS server options.
Add an EAP RADIUS server:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#radius server host fe80:0:0:0:21b:4fff:fe5e:73fd key radiustest used-by eapol
The following table defines parameters to configure an EAP-enabled RADIUS server with the radius server host command.
Variable
Value
host WORD<0–46>
Specifies the IP address of the selected server. RADIUS supports IPv4 and IPv6 addresses, with no difference in functionality or configuration.
WORD<0-20>
Specifies the secret key, which is a string of up to 20 characters.
The following table defines parameters to use optional arguments of the radius server host command.
Variable
Value
port <1-65535>
Specifies the port ID number.
priority <1-10>
Specifies the priority number. The lowest number is the highest priority.
retry <0-6>
Specifies the retry count of the account.
timeout <1-180>
Specifies the timeout of the server. The default is 30.
enable
Enables the functions used by the RADIUS server host.
acct-port <1-65536>
Specifies the port account.
acct-enable
Enables the account.
secure-enable
Enable secure mode on the server.
secure-log-level
Specifies the RADIUS secure server log severity level. Possible values are:
  • critical
  • debug
  • error
  • info
  • warning
secure-mode
Specifies the protocol for establishing the secure connection with the server.
secure-profile
Specifies the secure profile name.
