Use the following procedure to configure an actor priority value for a port. The MKA participant with the highest actor priority is designated as the key server.
Ensure that peers in an MKA connection are not configured with the same actor priority value.Procedure
- Select Chassis.
- Select the MACSec MKA Participants tab.
- Select a port.
- For ActorsPriority, double-click the field and type a value for ActorsPriority.
MACSec MKA Participants Field Descriptions
Name |
Description |
PortNumber |
Specifies the port number of the MKA session participant. |
CAName |
Specifies the Connectivity Association (CA) name associated with the MKA session participant. |
MKAProfileName |
Specifies the name of the MKA profile. |
MKA Enable |
Specifies whether MKA is enabled for the port. |
ActorsPriority |
Specifies a hexidecimal value for actor priority. The default is 10. |
