Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to display information about the VNID forwarding database (FDB).
- Select VTEP.
- Select the Vnid FDB tab.
Vnid FDB field descriptions
Use the data in the following table to use the Vnid FDB tab.
Name |
Description |
Vnid |
Displays the VNID IDs of the VXLAN tunnel endpoints. |
Address |
Displays all the learned MAC addresses in the forwarding database of the selected VNID. |
Status |
Displays whether or not the MAC address was learned. |
InterfaceIndex |
Displays the interface index name for the VNID. |
Type |
Displays whether the VNID is local or remote. |
