Configure ACE IP options
Configure ACE IP option entries to have the filter look for packets with an IP option specified.
The ACL exists.
The ACE exists.
Options field descriptions
Use the data in the following table to use the Options tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
Specifies the logical operator for the ACE IP options. Any is the only option. |
