Use the following procedure to clear Internet Protocol Security (IPSec) system statistics counters and view IPSec statistics on an interface. The device only clears system statistics counters on system reboot.
View IPSec statistics. Output is partial due to length.
Switch:1>show ipsec statistics system
IPSEC Global Statistics
InSuccesses = 0
InSPViolations = 0
InNotEnoughMemories = 0
InAHESPReplays = 0
InAHFailures = 0
InESPFailures = 0
OutSuccesses = 0
OutSPViolations = 0
OutNotEnoughMemories = 0
generalError = 0
InAHSuccesses = 0
InESPSuccesses = 0
OutAHSuccesses = 0
OutESPSuccesses = 0
OutKBytes = 0
OutBytes = 0
InKBytes = 0
InBytes = 0
--More-- (q = quit)
Switch:1>show ipsec statistics gigabitethernet 1/13
Ipsec Port Stats
Ifindex = 204
InSuccesses = 0
InSPViolations = 0
InAHESPReplays = 0
InAHFailures = 0
InESPFailures = 0
OutSuccesses = 0
OutSPViolations = 0
generalError = 0
Switch:1>show ipsec statistics vlan 1
Ipsec Vlan Stats
Ifindex = 2049
InSuccesses = 0
InSPViolations = 0
InAHESPReplays = 0
InAHFailures = 0
InESPFailures = 0
OutSuccesses = 0
OutSPViolations = 0
generalError = 0
View IPSec statistics for a loopback interface:
Switch:1>show ipsec statistics loopback 1
Ipsec LoopBack Stats
Ifindex = 1344
InSuccesses = 0
InSPViolations = 0
InAHESPReplays = 0
InESPReplays = 0
InAHFailures = 0
InESPFailures = 0
OutSuccesses = 0
OutSPViolations = 0
generalError = 0
Use the data in the following table to use the show ipsec statistics command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
loopback <1–256> |
Identifies the loopback interface. |
system |
Shows statistics for the entire system. |
vlan <1-4059> |
Specifies the VLAN. |
