The following sections provide procedural information you can use to configure Fabric Extend (FE) using Enterprise Device Manager (EDM).
Complete the configurations in the below table to configure Fabric Extend.
Step |
Procedure |
Description |
1 |
Configure the tunnel source address on the Globals tab. |
2 |
Configure the IS-IS logical interface for the Fabric Extend tunnel. |
3 |
Configure Fabric Extend on the switch at the other end of the tunnel |
Use the Fabric Extend procedures that apply to that switch model. |
For information about how to configure an IPsec NAT-T Responder, see IPsec configuration using EDM.
