Use the following procedure to enable IPsec on an IPv6 interface.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select IPSec.
  3. Select the IPv6 Interfaces tab.
  4. In the IpsecEnable column, double-click in the IpsecEnable field, and select enable from the drop-down box.
  5. Select Apply.
