Enable Trace Logs
Activates or disables the creation of trace logs. The default value is disabled.
Important
Important
Do not change this parameter unless directed by technical support.
    enable
    configure terminal
  2. Enable trace logs:
    boot config flags trace-logging
  3. Save the changed configuration.
