Perform this procedure to configure the remote hello interval to change how often hello packets are sent out from an interface level.
Configuring the remote hello interval on port 1/3:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitEthernet 1/3 Switch:1(config-if)#isis remote l1-hello-interval 1
The following table defines parameters for the isis remote l1-hello-interval command.
| Variable | Value |
| <1-600> |
Configures the Level 1 remote hello interval. The default value is 9 seconds. |
