Perform this procedure to display information about Energy Saver configuration on the ports.
  1. Enter Privileged EXEC mode:
    enable
  2. Display information about all ports or specify a particular port:
    show energy-saver interface [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
Switch:1>enable
Switch:1#show energy-saver interface
Port ES State PoE Savings PoE Priority
1/1       Enabled   Enabled     Low
1/2       Enabled   Enabled     Low
1/3       Enabled   Enabled     Low
1/4       Enabled   Enabled     Low
1/5       Enabled   Enabled     Low
1/6       Enabled   Enabled     Low
1/7       Enabled   Enabled     Low
1/8       Enabled   Enabled     Low
1/9       Enabled   Enabled     Low
1/10      Enabled   Enabled     Low
1/11      Enabled   Enabled     Low
1/12      Enabled   Enabled     Low
1/13      Disabled  N/A         N/A
1/14      Disabled  N/A         N/A
1/15      Disabled  N/A         N/A
