Assign an IP address to a VLAN to enable routing on the VLAN.
If you configure the SLA Mon agent address under an IP interface or VLAN, you must remove the SLA Mon address before you can remove the IP address or VLAN.
The ability to create an IP interface in a disabled state in one step is available only using CLI.
- Select VLANs.
- On the Basic tab, select the VLAN to configure.
- Select IP.
- On the Primary IP Address tab, select Insert.
- Configure the required parameters.
- Select Insert.
Primary IP Address Field Descriptions
Use the data in the following table to use the Primary IP Address tab.
Name |
Description |
Interface |
Shows the interface to which this entry applies. |
Ip Address |
Specifies the IP address to associate with the VLAN. |
Net Mask |
Specifies the subnet mask associated with the IP address of this entry. The value of the mask is an IP address with all the network bits configured to 1 and all the hosts bits configured to 0. |
Name |
Specifies a name for the interface. |
BcastAddrFormat |
Shows the IP broadcast address format on this interface. |
ReasmMaxSize |
Shows the size of the largest IP datagram which this entity can reassemble from incoming IP fragmented datagrams received on this interface. |
VlanId |
BrouterPort |
Indicates whether this entry corresponds to a brouter port, as oppose to a routable VLAN. |
MacOffset |
Specifies the MAC offset value. Routable VLANS are assigned MAC addresses arbitrarily or by offset. Their MAC addresses are:
If you enter the MAC offset, the lowest 12 bits are 0xA00 plus the offset. If not, they are arbitrary. |
IfType |
Identifies the type of interface. |
VrfId |
Associates the VLAN with a VRF. VRF ID 0 is reserved for the administrative VRF. |
