Configure an AS path list to restrict the routing information a router learns or advertises to and from a neighbor. The AS path list acts as a filter that matches AS paths.
  • To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  • The VRF must have an RP trigger of BGP.
  1. In the navigation pane, expand Configuration > IP.
  2. Select Policy.
  3. Select the As Path List tab.
  4. Select Insert.
  5. Enter the appropriate information for your configuration.
  6. Select Insert.
As Path List field descriptions
Use the data in the following table to use the As Path List tab.
Name
Description
Id
Specifies the AS path list.
MemberId
Specifies the AS path access list member ID.
Mode
Specifies the action to take if the system selects a policy for a specific route. Select permit (allow the route) or deny (ignore the route).
AsRegularExpression
Specifies the expression to use for the AS path.
