View and Delete Debug Files
Use this procedure to view and delete debug files.
Delete debug files to free space in the internal flash. As a best practice, delete these files to ensure enough space exists in intflash. New debug files do not overwrite old debug files. You must remove the file; otherwise, enough free space might not exist in the intflash to store the core dump if the switch fails or enough space might not exist for you to transfer a new release to the intflash of the switch to upgrade your switch.
The debug-file remove command can delete the following types of files:
  • core
  • archive
  • PMEM
  • dmalloc
  • flrec
  • wd_stats
If you want to delete a specific file, you must use the remove command. For more information, see VOSS CLI Commands Reference.
  1. To enter User EXEC mode, log on to the switch.
  2. View debug files:
    show debug-file [all][{slot[-slot][,...]]
  3. Delete debug files:
    debug-file remove [all]
  4. Enter Privileged EXEC mode:
    enable
  5. View core files:
    show core-files {slot[-slot][,...]]
The following example shows how you view all debug files for all slots.
Switch>show debug-file
                                   Core Files
Directory: /intflash/coreFiles/1
1.  File:    core.logServer.20120611084204.1.tar
    Created: Mon Jun 11 08:42:04 2012
2.  File:    core.trcServer.20120611084213.1.tar
    Created: Mon Jun 11 08:42:13 2012
3.  File:    core.logServer.20120611164647.1.tar
    Created: Mon Jun 11 16:46:48 2012
4.  File:    core.trcServer.20120611164652.1.tar
    Created: Mon Jun 11 16:46:52 2012
5.  File:    core.dbgServer.20120611164700.1.tar
    Created: Mon Jun 11 16:47:01 2012
6.  File:    core.logServer.20120611164740.1.tar
    Created: Mon Jun 11 16:47:41 2012
Remote CP Directory: /intflash/coreFiles/2
1.  File:    core.coreManager.x.20120612085548.2.tar
    Created: Tue Jun 12 08:55:49 2012
2.  File:    core.coreManager.x.20120612085602.2.tar
    Created: Tue Jun 12 08:56:02 2012
3.  File:    core.coreManager.x.20120612085553.2.tar
    Created: Tue Jun 12 08:55:56 2012
4.  File:    core.coreManager.x.20120612085558.2.tar
    Created: Tue Jun 12 08:56:00 2012
                                 Archive Files
Directory: /intflash/archive/1
1.  File:    archive.20120611083021.1.tar
    Created: Mon Jun 11 08:30:22 2012
2.  File:    archive.20120611163454.1.tar
    Created: Mon Jun 11 16:34:54 2012
3.  File:    archive.20120611164354.1.tar
    Created: Mon Jun 11 16:43:55 2012
4.  File:    archive.20120611164507.1.tar
    Created: Mon Jun 11 16:45:08 2012
Remote CP Directory: /intflash//archive/2
1.  File:    archive.20120611163507.2.tar
    Created: Mon Jun 11 16:35:08 2012
2.  File:    archive.20120611164408.2.tar
    Created: Mon Jun 11 16:44:09 2012
3.  File:    archive.20120611164521.2.tar
    Created: Mon Jun 11 16:45:21 2012
Directory: /intflash/archive/4
1.  File:    archive.20120611163515.4.tar
    Created: Mon Jun 11 16:35:18 2012
2.  File:    archive.20120611164416.4.tar
    Created: Mon Jun 11 16:44:20 2012
3.  File:    archive.20120611164529.4.tar
    Created: Mon Jun 11 16:45:33 2012
Directory: /intflash/archive/SF4
1.  File:    archive.20120611163536.SF4.tar
    Created: Mon Jun 11 16:35:40 2012
2.  File:    archive.20120611164436.SF4.tar
    Created: Mon Jun 11 16:44:39 2012
3.  File:    archive.20120611164549.SF4.tar
    Created: Mon Jun 11 16:45:53 2012
                                   PMEM Files
Directory: /intflash/PMEM/4
1.  File:    pmem.20120607194023.4.bin.gz
    Created: Thu Jun  7 19:40:23 2012
                                 DMalloc Files
                                  Flrec Files
                                 WdStats Files
Directory: /intflash/wd_stats/4
1.  File:    wd_stats.log.backup
    Created: Mon Jun 11 09:25:07 2012
The following example shows how to view only core files on the switch.
Switch#show core-files
                                   Core Files
1.  File:    core.1353113115.lifecycle.CP.1.gz
    Created: Fri Nov 16 19:45:15 2012
2.  File:    core.cbcp-main.x.20121114043335.1.tar
    Created: Wed Nov 14 04:35:36 2012
3.  File:    core.cbcp-main.x.20121114045202.1.tar
    Created: Wed Nov 14 04:54:03 2012
4.  File:    core.cbcp-main.x.20121114050825.1.tar
    Created: Wed Nov 14 05:10:26 2012
5.  File:    core.cbcp-main.x.20121114122506.1.tar
    Created: Wed Nov 14 12:27:07 2012
6.  File:    core.1353336274.lifecycle.CP.1.gz
    Created: Mon Nov 19 09:44:34 2012
7.  File:    core.1353319337.lifecycle.CP.1.gz
    Created: Mon Nov 19 05:02:17 2012
8.  File:    core.cbcp-main.x.20130122182946.1.tar
    Created: Tue Jan 22 18:32:08 2013
9.  File:    core.cbcp-main.x.20130220143809.1.tar
    Created: Wed Feb 20 14:38:10 2013
10.  File:    core.cbcp-main.x.20130225155025.1.tar
    Created: Mon Feb 25 15:50:25 2013
11.  File:    core.cbcp-main.x.20130225155407.1.tar
    Created: Mon Feb 25 15:54:07 2013
The following table defines parameters for the show core-files command.
Variable
Value
{slot[-slot][,...]}
Displays the core files for the slot that you select.
The following table defines parameters for the show debug-file command.
Variable
Value
all
Displays all types of debug files
{slot[-slot][,...]}
Displays debug files for the slot that you select. If you do not select a slot number, the device displays all types of the archived debug files present in a slot by slot basis. If you select a slot number, the device only displays archived files for the slot you select.
The following table defines parameters for the debug-file remove command.
Variable
Value
all
Removes all types of debug files in all slots.
If you use the option all with the remove debug-file command, then the device deletes all types of debug files, including the latest debug files.
