Use this procedure to display information about the groups configured in this device.
  1. In the navigation pane, expand the following folders: Configuration > IPv6.
  2. Click IPv6 MLD.
  3. Click the Group tab.
Group field description
Use the data in the following table to use the Group tab.
Field
Description
IPv6Address
Specifies the multicast group address that others want to join to. A group address can be the same for many incoming ports.
Members
Specifies the IP address of a source that has sent group report whishing to join this group.
InPort
Identifies a physical interface or a logical interface which has received group reports from various sources.
Expiration
Specifies the time left before group report expires on this port. This is updated upon receiving a group report.
IfIndex
