Perform this procedure to configure the Multi-area SPB layer 2 multicast I-SID list redistribution for the remote area.
- Select MultiArea.
- Select the L2 MC Redist Remote ISID List tab.
- Select Insert.
- In the ISID List Name field, type the name of the I-SID list.
- Select Enable.
- Optional: In the PolicyName field, type the policy name.
- Select Insert.
L2 MC Redist Remote ISID List Field Descriptions
Use the data in the following table to use the L2 MC Redist Remote ISID List tab.
| Name | Description |
| ISID List Name | Specifies the name of the I-SID list. |
| Enable | Enables Multi-area SPB layer 2 multicast redistribution for the specific I-SID list in the remote area. |
| PolicyName | Specifies the name of the redistribution policy. |
