Display the amount of memory used, memory available, and the number of files for internal flash memory.
- Select File System.
- Select the Storage usage tab.
Storage Usage Field Descriptions
Use the data in the following table to use the Storage Usage tab.
| Name | Description |
| IntflashBytesUsed | Specifies the number of bytes used in internal flash memory. |
| IntflashBytesFree | Specifies the number of bytes available for use in internal flash memory. |
| IntflashNumFiles | Specifies the number of files in internal flash memory. |
| UsbBytesUsed | Specifies the number of bytes used in USB device. |
| UsbBytesFree | Specifies the number of bytes available for use in USB device. |
| UsbNumFiles | Specifies the number of files in USB device. |
