Clear the MSDP SA Cache
Clear the SA cache to clear the SA entries the router learns from all the peers or a specific peer.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
- Select MSDP.
- Select the SA-Cache tab.
- Select Clear SA-Cache.
SA-Cache field descriptions
Use the data in the following table to use the SA-Cache tab.
Name |
Description |
GroupAddr |
Shows the group IP address of the SA cache entry. |
SourceAddr |
Shows the source IP address of the SA cache entry. |
OriginRP |
Shows the RP address of the SA cache entry. |
PeerLearnedFrom |
Shows the peer from which this SA cache entry was accepted. |
RPFPeer |
Shows the peer from which an SA message corresponding to the cache entry is accepted. |
InSAs |
Discontinuities in the value of this counter can occur at reinitialization of the management system. |
InDataPackets |
Shows the number of MSDP encapsulated data packets received that are relevant to this cache entry. |
UpTime |
Shows the time since this entry was first placed in the SA cache. |
ExpiryTime |
Shows the time remaining before this entry expires from the SA cache. |
