Use aggregate area ranges to reduce the number of link-state advertisements required within the area. You can also control advertisements.
Enable OSPF globally.
Ensure that the port uses an IP address.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
- Click OSPF.
- Click the Area Aggregate tab.
- Click Insert.
- Type the area ID.
- Select the type of link-state database.
- Type the IP address of the network.
- Type the subnet mask.
- Select the effect.
- In the AdvertiseMetric box, type a cost to advertise for the OSPF area range.
- Click Insert.
Area Aggregate Field Descriptions
Use the data in the following table to use the Area Aggregate tab.
Name |
Description |
AreaID |
Specifies the area in which the address exists. |
LsdbType |
Specifies the LSDB type:
IP Address |
Specifies the IP address of the network or subnetwork indicated by the range. |
Mask |
Specifies the network mask for the area range. |
Effect |
Specifies advertisement methods:
AdvertiseMetric |
Changes the advertised metric cost for the OSPF area range. |
ExtRouteTag |
Specifies the external route tag to be included in NSSA (type-7) LSAs. |
