Configure the Auto-sense Wait Interval for a PortNEW!
Perform this task to configure the time, in seconds, for Auto-sense to wait for a Link Layer Discovery Protocol (LLDP) neighbor to be detected in the Auto-sense wait state before transitioning to the Auto-sense onboarding state.
You can also complete this task on the Configuration > Fabric > AutoSense > Port AutoSense tab. For more information, see View or Modify the Auto-sense Port Configuration.
  1. In the Device Physical View tab, select one or more ports.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select General.
  4. Select the Interface tab.
  5. Type a value for AutoSenseWaitInterval.
  6. Select Apply.
