Use the following procedure to view a the remote MAC table for a C-VLAN.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Click VLANs.
  3. Click the Remote MAC tab.
Remote MAC field descriptions
Use the data in the following table to use the Remote MAC tab.
Name
Description
VlanId
Indicates the VLAN ID for this MAC address.
Addr
Indicates the customer MAC address for which the bridge has forwarding and/or filtering information
DestAddr
Indicates the provider MAC address for which the bridge has forwarding and/or filtering information.
PrimaryBVlanId
Indicates the primary B-VLAN ID for this MAC address.
PrimaryDestSysName
Indicates the primary system name of the node where the MAC address entry comes from.
PrimaryPort
Either displays the value 0, or indicates the primary port on which a frame came from.
SecondaryBVlanId
Indicates the secondary B-VLAN ID for this MAC address
SecondaryDestSysName
Indicates the secondary system name of the node where the MAC address entry comes from.
SecondaryPort
Either displays the value 0, or indicates the secondary port on which a frame came from.
SmltRemote
Indicates the MAC address entry for the remote vIST peer.
Status
Indicates the status of this entry:
  • other
  • invalid
  • learned
  • self
  • mgmt
