![Note](images/note.png)
This procedure only applies to VSP 4900
Series and VSP 7400
Series switches.
Perform this procedure to limit the number of packets that can be attached to an ACL ACE.
If you want to modify the ingress bandwidth rate limiter values, you must first disable
the ACE.
You can attach one policer to ACL and ACE. Every policer is independent.
Ensure that both the ACL and the ACE exist.
In the navigation tree, expand
Select Advanced Filters
(ACE/ACLs).
Select the appropriate ACL.
Select the appropriate ACE.
Select Policer.
Select Insert.
For SvcRateValue, type the service rate value.
For PeakRateValue, type the peak rate value.
Select Insert.
Select Apply.
