Use the following procedure to generate the private and public key pair for the specific cryptography type.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select Certificate.
  3. Select the Key-Pair tab.
  4. Select Insert.
  5. In the Type field, select the cryptography type.
  6. In the Size field, type the size of the key.
  7. Select Insert.
Certificate key-pair field description
Use the data in the following table to use the Certificate > Key-Pair tab.
Name
Description
Type
Specifies the cryptography algorithm used to generate the key-pair.
Only RSA is supported.
Size
Specifies the size of the key-pair to be generated.
Only 2048 is supported.
Name
Specifies the name of the key-pair generated for the subject.
This name is auto-generated as the combination of key-type and key-size.
