Use the data in the following table to help use the IP Interface tab.
By default, the switch enables an IP interface after you configure the primary IP address. You can administratively disable, and then reenable, an IPv4 interface after you create it. For example, if you want to change the routing protocol configuration on the interface.
This procedure applies to the IP Layer and functionality for the brouter port.
The ability to create an IP interface in a disabled state in one step is available only using CLI.
  1. On the Device Physical View tab, select one or more ports.
  2. In the navigation pane, expand Configuration > Edit > Port .
  3. Select IP.
  4. Select the IP Interface tab.
  5. Change the AdminStatus value to change the administrative state.
  6. Select Apply.
IP Interface
Name Description
AdminStatus
Modifies the administrative state of the IP Interface. By default, the switch enables an IP interface after you configure the primary IP address.
OperState
Displays the operational state of the IP Interface.
