Access to the CLI varies for two account types: "admin" and "user". The admin account provides administrator access to all the contexts and features in the CLI, while the user account provides no access to contexts and command availability is limited.
The following example displays commands available in the root context for the admin account type.
EWC.extremenetworks.com# help Available commands are: ap Modify Access Point settings availability Modify availability settings copy Transfer files between the controller and an external server cos Configure Controller cos settings end Return to the base mode exit Return to the previous mode export Export Controller data to a file flash Mount/Unmount flash drive healthpoll Set healthpoll timeout host-attributes Configure Controller host attributes settings import Restore Controller data/configuration from file ip Modify controller route key Modify License Keys l2ports Configure Controller L2 Ports settings lanset Set Ethernet link parameters lbs Modify settings for AP location based service login Configure login settings. loglevel Set a log level logout Logout mitigator Modify Mitigator settings to assist in detection of rogue AP mobility Modify access controller mobility settings no Clear the command setting ping Ping a host or gateway policy Configure Controller policy settings radtest Test Radius Server connectivity, Captive Portal and EAP authentication radtest_mba Test Radius Server connectivity and MAC-based authorization reset Reset database configuration restart Restart a process schedule_backup Modify backup schedule schedule_upgrade Scheduled upgrade secureconnection Modify access controller secure connection settings show Display settings shutdown Used to safely halt or reboot the controller site Configure site settings snmp Configure SNMP settings syslog Change syslog settings tech_support Collect tech support data time Configure network time for the Controller topology Configure Controller topology settings traceroute Traceroute a host or gateway traffic_capture Traffic capture on interface upgrade Utility for upgrading AC software (AC), or AP software (APUP) upgrade_backup_dest Set ftp parameters for full disk clone backup upgrade_image_src Set location of upgrade image, if remote upgrade is being performed users Change Controller user settings vnsmode Modify Controller VNS(Virtual Network Segment) settings web Modify web settings wlans Configure WLAN Service settings
