Use the fast-failover command in the wlans:<WLAN-service-name>:auth RADIUS server configuration context to enable or disable the sending of interim account records (to the RADIUS server) when a failover occurs and the session home moves to the availability partner.
After you run the fast-failover command, run the apply command to implement the changes.
| enable | Enables the sending of interim account records to RADIUS for fast failover. |
| disable | Disables the sending of interim account records to RADIUS for fast failover. |
This command overwrites the global RADIUS fast-failover command.
To get to the RADIUS server configuration, enter the config <named radius> role acct command. After applying changes, exit the RADIUS server configuration context by the config exit command.
This example disables fast failover:
EWC.extremenetworks.com:wlans:cnl-AAA:auth# fast-failover disable EWC.extremenetworks.com:wlans:cnl-AAA:auth# apply
Print
this page
Email this topic
Feedback
