push-client-reportingUse the push-client-reporting command to generate a unique report with data from the MU_Table, published through the REST Push Publisher. The push-client-reporting command is accessible from within the location:publish context.
| enable | disable | Enables or disables the push operation on the controller. |
In location-based applications and user traffic analytics, integrating partners often require more detail than simply the location of a MAC address. The client reporting option allows users to generate a report with details from the MU-Table.
The following example enables the push operation on this controller:
EWC.extremenetworks.com:location:publish# push-mu-reporting enable
Print
this page
Email this topic
Feedback
