port
Use the port command to configure the DAS port. The port command is available from the vnsmode:das context.
port 1024-65535
Parameters
1024-65535 Specifies the DAS port.
The following example sets the DAS port number to 3799:
EWC.extremenetworks.com:vnsmode:das# port 3799
