pwd-ignore-similar
Use this command to enable or disable the ability to ignore similar characters when generating the password pattern. The pwd-ignore-similar command is available in the wlan:<WLAN-service-name>:auth:captiveportal context.
pwd-ignore-similar enable | disable
Parameters
enable Enable ignoring similar characters when generating the password pattern.
disable Disable ignoring similar characters when generating the password pattern.
