hostname
Use the hostname command to configure a hostname for the controller.
After you have run the hostname command, run the apply command to implement the changes.
hostname name | none
Parameters
name Specifies the hostname of the controller.
none Removes the configured hostname.
The following example specifies that the host name of the controller should be EWC123.
EWC.extremenetworks.com:host-attributes# hostname EWC123
EWC.extremenetworks.com:host-attributes# apply
