serviceUse the service command to enable or disable an AeroScout, Ekahau, or Centrak location-based service on the Wireless Appliance. The service command is accessible from the lbs context of the CLI.
| disable | Disables location-based service. |
| aeroscout | Enables Aeroscout location-based service. |
| ekahau | Enables Ekahau location-based service. |
| centrak | Enables Centrak location-based service. |
Centrak and Ekahau configuration offer a default port number and multicast address, but you can modify the default values if necessary.
Now assign APs to participate in the location-based service.
For more information, see lbs-status.The following example enables the Centrak location-based service:
EWC.extremenetworks.com# lbs EWC.extremenetworks.com:lbs# service centrak
