Use the filter command to enable or disable multicast filtering support. The filter command is available from the topology:<named-topology>:l2:multicast context of the CLI for b@ac, b@ap, and routed topologies.
| enable | Indicates that multicast filtering support is enabled. |
| disable | Indicates that multicast filtering support is disabled. |
This example enables multicast filtering support:
EWC.extremenetworks.com:topology:test:l2:multicast# filter enable
Print
this page
Email this topic
Feedback
