Use the secure-tunnel-ap command to enable or disable the encryption of control traffic between APs on this site. The secure-tunnel-ap command is accessible from the site:<named-site> context.
| enable | disable | Enables or disables secure tunnels between APs on this site. |
The secure-tunnel command must be enabled before the secure-tunnel-ap command can be run.
The following example enables secure tunnels between APs on site1:
EWC.extremenetworks.com:site:site1# secure-tunnel enable EWC.extremenetworks.com:site:site1# secure-tunnel-ap enable
Print
this page
Email this topic
Feedback
