hs-up-speed
Use the hs-up-speed command from the hotspot context to configure the hotspot WLAN metrics Uplink speed.
hs-up-speed (0-2147483647)
Parameters
(0-2147483647) Specifies the WLAN metrics Uplink speed in kbps.
EWC.extremenetworks.com:wlans:hs:hotspot# hs-up-speed 2147483647
