balanced-power
Use the balanced-power command to simplify the power settings so that they apply to all channels in the channel list.
balanced-power enable | disable
Parameters
enable Power settings apply to all channels in the channel list.
disable Power settings do not apply to all channels in the channel list.
EWC.extremenetworks.com:ap:defaults:3935FCC# balanced-power enable
