Use the client command to configure the guest portal client access account.
id | Specifies the ID of the guest access account and must begin with the string “Guest-” |
name | Specifies the name of the client |
passwd | Specifies the password used by the client |
acct_start | Specifies the activation start time of the client account (in the form YYYY-MM-DD HH:MM:SS) |
account_lifetime | Specifies the amount of time the client account will remain viable |
session_lifetime | Specifies the amount of time the client session will remain viable |
The following example configures a client guest access account named “Lobby”:
EWC.extremenetworks.com:wlans:clients# client Guest-lobby Lobby 1234abcd 2009-12-01 12:00:00 12 12 EWC.extremenetworks.com:wlans:clients# show Guest-lobby Lobby 1234abcd 2009-12-01 12:00:00 12 12 00:00 00:00 disabled
