Use the voice-admission-control command to enable global admission control for voice for WLANS. The voice-admission-control command is accessible from the wlan:<WLAN-service-name>:qos-policy context of the CLI.
After you run the voice-admission-control command, run the apply command to implement the changes.
| enable | disable | Enables or disables global admission control for voice for WLANS. |
This command is only available when either the 802.11e or wmm commands have been enabled. For more information, see dot11e and wmm.
The following example enables global admission control for voice for the CNL-7-CP WLANS:
EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# voice-admission-control enable EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# apply EWC.extremenetworks.com:wlans:CNL-7-CP:qos-policy# show voice-admission-control Use Global Admission Control for Voice (VO): enable
Print
                        this page
Email this topic
Feedback
