Use the sync command to enable or disable automatic synchronization of this <named-cos> across paired controllers. Refer to the section entitled “Using the Sync Summary,” in the Wireless User Guide for more information about synchronization of CoS.
The sync command is accessible from within the cos:<named-cos> context.
| enable | disable | Enables or disables automatic synchronization of this <named-cos> across paired controllers. |
The following example enables the synchronization of the my-cos CoS across controllers:
EWC.extremenetworks.com:cos:my-cos# sync enable EWC.extremenetworks.com:cos:my-cos# apply EWC.extremenetworks.com:cos:my-cos# show Name: my-cos Use Legacy Priority Override defined in the WLAN Service: disable 802.1p Priority: none ToS/DSCP Marking: Mask: Inbound Rate Limit: Outbound Rate Limit: Transmit Queue: none Synchronize: enable EWC.extremenetworks.com:cos:my-cos#
Print
this page
Email this topic
Feedback
