Use the stbc command to enable or disable the 11n advanced STBC feature. The stbc command is accessible from all radio contexts of the CLI.
| enable | Enables the 11n advanced STBC feature. |
| disable | Disables the 11n advanced STBC feature |
The following example enables STBC on radio1:
EWC.extremenetworks.com:ap:defaults:ap37xx:radio1# stbc enable
Print
                        this page
Email this topic
Feedback
