Use the status command to enable or disable this WLAN service. The status command is accessible from the wlans:<WLAN-service-name> context of the CLI.
After you run the status command, run the apply command to implement the changes.
| enable | disable | Enables or disables this WLAN service. |
The following example enables this WLAN service:
EWC.extremenetworks.com:wlans:test# status enable EWC.extremenetworks.com:wlans:test# apply EWC.extremenetworks.com:wlans:test# show status Enable status: enable
Print
this page
Email this topic
Feedback
