Use the assign-ap command to add or remove an AP from the site.
The assign-ap command is accessible from the site:<named-site> context.
| add | delete | Specifies whether to add or delete the identified AP. |
| ap serial | Specifies the AP to be assigned by its serial number. |
You specify the AP by its serial number. If you enter the command without an AP serial number, the CLI displays a list of available APs by their serial numbers and, if named to the system by an ap:<serial> context name command, the AP name.
The following example shows a listing of available APs:
EWC.extremenetworks.com:site:site1# assign-ap The available APs: 0500009353050067(EWC-3801) 050000829F737045(050000829F737045) 0409920201204015(C25-AP3710) 0500009203050048(C25-AP3705-50048) 0500009203050013(C25-AP3705) 10490066235A0000(AP-3801-Ext) 0509920201203250(EWC-AP-3710-3705-Ext) 0002000819006723(C25-AP3801) 0002010803508865(0002010803508865) 10210066235A0000(C25-AP3705)
This example shows AP added to the site1 site:
EWC.extremenetworks.com:site:site1# assign-ap add 050000829F737045
Print
                        this page
Email this topic
Feedback
