cluster-encryption
Use the cluster-encryption command to enable or disable the encryption for the cluster shared secret. The cluster-encryption command is accessible from the ap:registration context of the CLI.
cluster-encryption enable | disable
Parameters
enable | disable Enables or disables the encryption for the cluster shared secret.
The following example enables the encryption for the cluster shared secret:
EWC.extremenetworks.com:ap:registration# cluster-encryption enable
